Low Sound Problem
(Topic created on: 05-30-2026 11:26 PM)
Prianka1
I am facing Low Sound Problem of my Samsung Galaxy A06. Any suggestions for solution please?
5 Comments
Kutty12
Try using the diagnostic mode
goodthings
Kindly complaint to Samsung customer care support through Samsung Members app as error report also send log files along with this error report for this issue and wait for next update it's maybe fix by Samsung team soon. If you like please accept it's as a solution it's help to other users also, click on 3dots in my reply section and click on accept solution.
goodthings
You're welcome to here.
cs_member10
Dear Samsung Member,
As per your concern regarding the low sound issue. We would request you to kindly perform the following steps to resolve your issue.
● Disconnect anything plugged into the headphone jack like, a selfie stick, headphones, Bluetooth, etc.
Remove any third-party case, protective films, or any other accessory that usually comes in contact with your device.
● Check device volume settings: Tap on Settings > Sound & vibration>Volume > Drag the volume adjustment bar left or right to increase or decrease the device volume.
To verify, play music and check the music sound. If the sound quality is good, then your speaker is working fine.
● Clear Sound Picker data: Settings> Apps> Filter and Sort> Enable Show system apps> OK>Search Sound Picker> Storage> Clear data of Sound Picker.
● Clear Sound Alive data: Settings> Apps> Filter and Sort> Enable Show system apps> OK>Search Sound Alive> Storage> Clear data.
● Clear Adapt sound data: Settings> Apps> Filter and Sort> Enable Show system apps> OK>Search Adapt Sound> Storage> Clear data.
● Reset app preferences: Settings> Apps> Three dots> Reset app preferences> Reset.
● Update the software if available: https://www.samsung.com/in/support/mobile-devices/samsung-galaxy-smartphone-how-to-update-software/
1. Kindly create a data backup of your device via the SMART switch mobile application or http://www.samsung.com/in/support/smartswitch pc suite.
After performing the troubleshooting steps if the issue still persists, kindly visit the service center for your query. Please click on the link mentioned below to get a nearby service center to your pin code:
http://www.samsung.com/in/support/servicelocation/
ABHAY0110
Due to single speaker
