03-27-2024 08:27 PM in
Galaxy A1 Solution
03-27-2024 11:56 PM in
Galaxy A- Mark as New
03-28-2024 08:49 AM in
Galaxy ADear Samsung Member,
As per your concern, we would request you kindly perform the following steps to resolve your Battery drain issue and heating issues.
Galaxy device Battery drain issue: https://www.samsung.com/in/support/mobile-devices/how-can-i-optimise-and-extend-the-battery-life-on-...
Galaxy device heating issue: https://www.samsung.com/in/support/mobile-devices/why-the-device-heats-up-during-use/
04-07-2024 02:11 PM in
Galaxy ASettings 》Connections 》More connection settings 》Printing 》Turn off default printing service
Device care 》Battery 》Background usage limit 》Deep sleeping apps 》 add apps
Settings 》Location 》Improve Accuracy 》Turn off Bluetooth and WiFi scanning
