Resolved! Solved
A36 5g battery draining bery fast and heating issue.
(Topic created on: 05-01-2025 01:17 PM)
prakam1097
Just purchased a36 5g a minth ago. Its battery performance and heating issue is very annoying ....kidly work on these issue
goodthings
Kindly complaint to Samsung customer support through Samsung Members App as error report also send log files Along with this error report for this issue and wait for next update may be fix it by Samsung team soon. If you like please accept as a solution it's help to others users also ,click on 3dots in my reply section and click on accept solution . Thanks.
6 Comments
goodthings
prakam1097
How can i get log report
goodthings
Please go to main page of Samsung Members App, click on support, click feedback, click error report then follow instructions on screen. Log files automatically send by system immediately after send error report but don't close Samsung Members App during this process untill complete. If you like please accept as a solution it's help to others users also, click on 3dots in my reply section and click on accept solution. Thanks.
goodthings
Your's most welcome to here.
cs_member10
Dear Samsung member,
Please perform the below-mentioned troubleshooting steps, these may help in resolving your concerns.
▶ Galaxy device Battery drainage issue: Note: Charge in one go instead of charging many times as it affects the life span of battery and battery performance.
2. Check device network fluctuation.
3. Adjust screen timeout settings: Go to Settings > Display > Screen timeout > Select the minimum screen timeout.
4. Check which application is or interface is using more battery from device care and try to update app or avoid using that app.
6. Turn off auto sync of e-mails, app data etc.
▶ Galaxy device heating issue: 1.Turn off Wi-Fi, GPS, Bluetooth, and other connectivity features when not using them.
2. Decrease the screen brightness.
3. Close background running apps.
4. Uninstall the unnecessary apps.
5. Reduce long duration of graphics intensive gaming sessions as it may cause heating issue.
6. Avoid usage of mobile phone when charging.
7. Update software: Go to Settings > Software update > Download and install > Check for software update > If Software update available > Download > Downloading updates > Install now
8. Reset the device:
IMPORTANT:
• For this:
Please follow the below steps to reset the device: Settings > General Management > Reset > Temporary cloud backup or External storage backup > tap on Factory data reset (This will erase all data, including files and downloaded apps)
If the issue still persists, after performing all troubleshooting steps, would request you to please visit the service center. Below is the link to find nearest service center
http://www.samsung.com/in/support/servicelocation/
InduDevi
Just purchased a36 5g two days ago. Its battery performance and heating issue is very annoying ....kidly work on these issue
