Galaxy A53 5g faces heating and battery draining issue
(Topic created on: 10-15-2023 09:23 AM)
Not applicable
I am using the galaxy A53 5G for almost 3 week, the phone is heating up frequently even in normal use and the battery is also draining very fast, I have to charge the phone twice in normal use. Can this issue be resolved ?
N.B. : I have also tested in safe mode but nothing resolved.
3 Comments
Same here bro....I bought this phone Dec 2022 still I am facing heating issue....if I used camera more time or scan document it will heat up tremendously....I complaint against them but no use...also not trusty service center available...bogas / bakwas manufacturing..
Saurabh1977
Heating and battery drain issue is there is most of the cases. Samsung is not able to resolve this issue. The processor is also not optimised and is slow when compared to phones in the same price point
cs_member10
Dear Samsung Member,
Galaxy device heating issue: https://www.samsung.com/in/support/mobile-devices/why-the-device-heats-up-during-use/
Galaxy device battery drain issue
Charge in one go instead of charging many times as it affects the life span of the battery and battery performance
Perform Battery Optimization
Settings > Select Device Maintenance/Device Care/Battery and device care > Optimize > Optimize all options like Battery, Storage, and Memory
Turn off Wi-Fi, GPS, Bluetooth, etc.
Turn off unused functions like Wi-Fi, GPS, Bluetooth, and location settings when not using them: On the home screen swipe down the notification panel > Turn off Wi-Fi, GPS, Bluetooth, and other connectivity features when not using them.
Check device network fluctuation
Kindly check whether the mobile network fluctuates frequently or if the network signal is low in your area. In both cases, the battery will drain considerably fast.
Recommendation: We recommend you avoid using it in areas with low network/fluctuation.
Reduce display brightness level
Kindly set the device display brightness in auto mode (If available).
Adjust screen timeout settings: Settings > Display > Screen timeout > Select minimum screen timeout.
Check and update the App: Kindly check which application or interface is using more battery from device care. And try to update the app or avoid using that app.
Close background running apps
Close all the background running apps when not using them,
Turn off auto sync of e-mails, app data, etc.
We request you turn off the auto sync option, it will stop the synchronization of the device with the server & reduce the battery drainage.
The steps to turn off auto sync are:
2. Turn off the auto sync option.
Check your device in safe mode: https://www.samsung.com/in/support/mobile-devices/safe-mode-on-samsung-phones/
Reset your device: https://www.samsung.com/in/support/mobile-devices/samsung-galaxy-mobile-how-to-perform-a-factory-res...
In case the issue still occurs kindly visit the service center for a physical inspection of your device. You can locate your nearest service center with this given link: https://www.samsung.com/in/support/service-center/
