15 hours ago (Last edited 15 hours ago ) in
Galaxy A- Mark as New
15 hours ago in
15 hours ago in
15 hours ago in
15 hours ago in
14 hours ago in
13 hours ago in
13 hours ago in
7 hours ago in
Galaxy ADear Samsung member,
3. Check device network fluctuation. Avoid usage in areas with low network/fluctuation.
9. Update software: Go to Settings > Software update > Download and install > Check for software update > If Software update available > Download > Downloading updates > Install now
10. Reset the device:
IMPORTANT:
• For this:
If the issue still persists, after performing all troubleshooting steps, would request you to please visit the service center. Below is the link to find nearest service center
http://www.samsung.com/in/support/servicelocation/
