TanmayRajThakur 123
10-13-2024 07:45 AM in
1) Always take care of your phone, keep it clean and if possible avoid using it in hot temperature.
2) Restart your phone every 2 days, or make a schedule for that.
3) If your phone is very powerful i.e
S series them use light system profile.
4) Turn on dark mode to improve battery life and avoid eye strain and heating.
5) Don't fill up your phone by unnecessary apps. Only use necessary apps and uninstall others.
6) Use galaxy app booster after every os update to get good performance.
7) Stick to the habit of screen timers to keep phone cool and improve productivity.
😎 Put background apps to sleep which consumes too much battery in background. I don't suggest deep sleeping because you can't update apps after it.
9) To have nice animations, put one ui home in unrestricted battery usage.
10) Make a routine to turn off notifications during gaming except important ones.
11) Hard reset your phone every 6 months.
12) Keep adaptive brightness on.
13) turn on maximum battery protection to reduce speed of wearcycles and load on battery.
14) Better turn off fast charging when charging at night.
15) Always check screen on time regularly
13 Comments
- « Previous
- 1
- 2
- Next »
TanmayRajThakur 123
10-13-2024 10:41 AM (Last edited 10-13-2024 10:42 AM ) in
Hey there!
I've heard mixed reviews about the S24 Ultra's camera processing. Some people love the results, while others have found it to be a bit overprocessed or inconsistent. It seems like it depends on individual preferences and shooting conditions.
Have you tried adjusting the camera settings, like turning off Intelligent Optimization or using the Pro mode for more manual control? That might help you get the results you're looking for.
If you're still having issues, you might want to check at service centre phone
Surya230
10-13-2024 11:33 AM (Last edited 10-13-2024 11:41 AM ) in
1) Done.
2) I think restarting in every 2 day not a good idea. Restart atleast once in a week is better in my opinion.
4) Scheduled for it.
5) Yes.
6) My phone doesn't support GoodLuck.
😎 Putting apps to sleep is good for your battery.
11) But why ?
12) I enable when I go outside.
13) Done.
14) Yes.
5) Yes.
11) But why ?
13) Done.
14) Yes.
TanmayRajThakur 123
10-13-2024 02:47 PM (Last edited 10-13-2024 02:48 PM ) in
Restarting is individual choice
Use fine lock if your phone doesn't support it, many tutorials are available online.
Hard reset cleans the phone, making it much faster, many people suggest about it.
However I see that the 8 and small bracket is converted to 😎 in your post too 😅😅
Surya230
10-14-2024 09:24 AM in
Yes 😎
- « Previous
- 1
- 2
- Next »
