11-23-2024 09:11 PM in
Galaxy A- Mark as New
11-23-2024 09:19 PM in
11-29-2024 08:35 PM in
Galaxy AHow long will the battery last using social media if the internet is on on the Samsung A15?
11-23-2024 09:20 PM in
11-23-2024 10:17 PM in
Galaxy A1. *Check Battery Health*: Go to _Settings_ > _Battery and device care_ > _Battery health_. If your battery health is below 80%, it might be causing the drain.
2. *Disable Power-Hungry Features*: Turn off features like Bluetooth, GPS, and Wi-Fi when not in use.
3. *Adjust Screen Brightness*: Lower your screen brightness or enable Auto-brightness.
4. *Turn Off Always-On Display*: Go to _Settings_ > _Lock screen_ > _Always-on display_ and toggle it off.
5. *Close Unused Apps*: Regularly close apps you're not using to prevent them from running in the background.
*Advanced Troubleshooting*
1. *Boot in Safe Mode*: Restart your device in Safe Mode to isolate if a third-party app is causing the issue.
2. *Reset App Preferences*: Go to _Settings_ > _Apps_ > _Three-Vertical Dots_ > _Reset app preferences_.
3. *Disable Adaptive Battery*: Go to _Settings_ > _Battery and device care_ > _Battery_ > _Adaptive battery_ and toggle it off.
4. *Check for Software Updates*: Ensure your device is running the latest software. Go to _Settings_ > _Software update_ > _Download and install_.
*Additional Tips*
1. *Use a Battery Saver App*: Consider using a battery saver app like Samsung's built-in "Device care" or third-party apps like Greenify or Du Battery Saver.
2. *Avoid Overcharging*: Try to keep your battery level between 20% and 80% if possible.
3. *Clean Your Device*: Regularly clean your device's charging port and ensure it's free from dust and debris.
By following these steps, you should be able to identify and resolve the battery drain issue on your Samsung A15.
If this reply answered your query please mark my reply as "resolved" by clicking 3 vertical dots on top right of my reply. Thank you 😊
11-26-2024 11:07 AM in
Galaxy ADear Samsung Member,
As per your concern, we would request you kindly perform the following steps to resolve your issue by the given links.
● Galaxy device Battery drain issue: https://www.samsung.com/in/support/mobile-devices/how-can-i-optimise-and-extend-the-battery-life-on-...
→ Update the software if available: https://www.samsung.com/in/support/mobile-devices/samsung-galaxy-smartphone-how-to-update-software/
→ You can reset your device by following the steps.
If the issue still occurs, please visit the service center for a physical inspection of your device. You can locate your nearest service center with this given link: https://www.samsung.com/in/support/service-center/
