Resolved! Solved
Battery drain problem galaxy a35
(Topic created on: 12-03-2024 07:45 PM)
sagarjain88
Bhai log phone bhi heat kr raha h or battry bhi fas low ho rahi h kisi or ko bhi y problem ho rahi h kya
goodthings
4 Comments
goodthings
goodthings
Your's most welcome to here.
Gouthambhati
I'll suggest you that you should search in youtube for your battery related issues, you will find better option for your device and I am also using A35 5G,
cs_member10
Dear Samsung Member,
As per your concern, we would request you kindly perform the following steps to resolve your issues by given links.
● Galaxy device battery drain issue: https://www.samsung.com/in/support/mobile-devices/how-can-i-optimise-and-extend-the-battery-life-on-...
● Galaxy device heating issue: https://www.samsung.com/in/support/mobile-devices/why-the-device-heats-up-during-use/
● Reset your device: https://www.samsung.com/in/support/mobile-devices/samsung-galaxy-mobile-how-to-perform-a-factory-res...
