3 weeks ago in
Galaxy A- Mark as New
3 weeks ago in
Galaxy ASometimes, a recent software update might not be optimized for battery efficiency. Check if there are any pending updates or reported issues with the current version of your phone’s software.
If you like it, please
accept it as a solution. It will help other users as
well. To do this, click on the three dots in my reply
section and then click on "Accept solution."
#GalaxyGallery #HelpfulCommunity
3 weeks ago in
Galaxy ADear Samsung Member,
As per your query, we want to inform you that the Protect protection features optimize battery lifespan and performance while ensuring safety. However, Sometimes the battery drains due to could occur due to usage and various other factors like applications running in the background, high screen brightness, enabled push email settings, or possibly a faulty battery.
If you are facing more battery draining as compared to normal, kindly perform the following steps by a given link to resolve your issue: https://www.samsung.com/in/support/mobile-devices/how-can-i-optimise-and-extend-the-battery-life-on-...
You can check the device in safe mode and for the same mode you can tap on the given link. https://www.samsung.com/in/support/mobile-devices/safe-mode-on-samsung-phones/
In case the issue still occurs, kindly report the problems with a log file. To share a log file, click on the Samsung Members Application (Open Samsung Members Application > Support> Tap on error report > Type your query > Send).
3 weeks ago in
Galaxy APrevious models had their cut off at 85%. Now its 80 or so in A55.
3 weeks ago in
