raajjjj
7 hours ago in
Galaxy ASamsung A35 Battery Life Issue β Seeking Your Feedback!
Hello everyone,
I've been experiencing some battery life issues with my Samsung Galaxy A35 for a while now. It feels like the battery drains much faster than it should with typical usage. Even after a full charge, it significantly drops within a few hours.
If any of you are using a Samsung A35, could you please share how your phone's battery life is holding up?
* Are you facing a similar problem?
* What's your typical battery life like? (For example, how long does it last with a full charge?)
* Have you found any solutions to this issue? (Such as changing settings, uninstalling apps, etc.)
Your feedback would be incredibly helpful for me to understand this issue better and, if needed, contact Samsung support.
Thank you.
Have a great year ahead.
6 Comments
Wodehouse
7 hours ago in
Simple steps to save battery at the cost of sacrificing luxury
1 Enable Power saver
2 Enable performance mode light
3 Enable adaptive power saving instead of basic
4 Enable adaptive brightness
5 Disable AOD
6 Enable extra dim
7 Change display to natural
8 Screen time out to 30 secs (system default)
9 Record videos in FHD
10 Restrict gaming to HD or FHD and slower frame rate
11 Switch to dark mode
12 Disable near by device scanning
13 Disable WiFi scanning
14 If 5G is unavailable change network to LTE/3G/2G
15 Allow the battery to drain completely and recharge,say once a month.
16 Enable auto restart
17 Run device care
18 Disable apps running in background.
19 Disable RAMplus if you dont use memory intensive apps and do heavy multi tasking. Available RAM usually around 2 to 3 Gb is more than sufficient for normal tasks.
20 Uninstall bloat ware that came with your phone,eg. Spotify,LinkedIn etc.
21 Set display motion smoothness to standard.
You can mix match the steps above and arrive at a usage based on your needs.
If this reply answered your query please tap 3 vertical dots to the right of my reply and tap "Resolved". Thank you π
5 Disable AOD
6 Enable extra dim
17 Run device care
SATYA35
7 hours ago in
Battery decent but the main thing is performance πππππππππππππππ
armlinker4639
6 hours ago in
I also have Galaxy A35
How old is your A35?
Did this happen after ONE UI 7 update?
How long have you been experiencing it?
BiRdMaN
6 hours ago in
It is a BUG send an error report along with log files to customer support through this members app and Samsung will fix it in the next update. To do that follow this procedure
Open Samsung Members Application > Support> Tap on send feedback> Choose Composer> Select error report> Select the appropriate issue category> Type your query and send.
If you find this helpful please Accept it as a solution Thank you π
armlinker4639
5 hours ago in
Here is my battery stats
1. Todays SOT.
The screen off time includes 5% Hotspot drain + 5% idle drain.
2. SOT since last charge.
1. Todays SOT.
Pseudonymous
a minute ago (Last edited 13 seconds ago ) in
How many hours you would get battery backup in a35
Because in mine case in full charge i would get backup of 3 to 3.30 hrs
