02-16-2023 11:09 AM in
Galaxy A![Moderator Moderator](/i/rank_icons/moderator.gif)
02-22-2023 03:27 PM in
Galaxy ADear Samsung member,
We acknowledge your query and apologize for the inconvenience caused to you and will surely assist you regarding the same. And please follow the easy troubleshooting steps which might help to solve the issue.
Settings > Select Device Maintenance/Device Care > Optimize > Optimize all options like Battery, Storage and Memory
Kindly turn off the smart features of the device and other connectivity features when not in use, which will eventually help you to reduce battery power consumption (smart features such as Motion gestures in advance feature and Bluetooth, Wi-Fi, Hotspot, etc.).
Please follow the below steps:
2. Tap on Bluetooth, Location/GPS, Wi-Fi, Mobile hotspot, NFC, etc. to turn off.
In case the issue still occurs. Please register your concern in Samsung Members Application (Open Samsung Members Application > support> tap on error repot > type your query > send).
Warm regard,
![](/skins/images/059B16E50476BC4E49A9BE590DC35EDD/responsive_peak/images/icon_anonymous_message.png)
