08-20-2020 12:49 PM in
Galaxy ASolved! Go to Solution.
08-21-2020 10:33 PM in
Galaxy Ato know exact battery screen on time
then we can understand the issue
08-22-2020 04:30 PM (Last edited 08-22-2020 04:30 PM ) in
Galaxy AI usually charge when the phone reaches 20%
so the phone lasted 5.6 hrs to this point which is better than before but still bad
as you can see I did not play any games and no Hotspot too.
youtube ate a bit more than expected but its fine I can live with that until next update.
the sot is 6hrs 38 mins minus 58 minutes because i used the phone at night too.
I started the test at 10 am with full battery.
please confirm and tell if something is wrong
and yes brightness was at around 20-25% range
calling for 10 mins only
thanks you've helped a lot
08-22-2020 04:45 PM in
Galaxy Ain my opinion its good enough considering 4000 mah battery
and still 23% remained so as per my experience it will last atleast 2 hours more
then total SOT would be approximately 8 hours
and its not bad at all dear.
so my advise is not be over thinking towards battery time.
M series user having 6k and their average sot is 10-12 hour.s only.
08-22-2020 04:48 PM in
Galaxy Astop thinking all time about battery.
as this may vary time to time as per uses pattern.
08-22-2020 05:49 PM in
Galaxy A- Mark as New
08-25-2020 10:40 AM in
Galaxy Athe main problem is this update
08-25-2020 10:49 AM in
08-25-2020 11:36 AM in
08-25-2020 11:41 AM in
Galaxy Athis time hopefully you will enjoy new software 😁😁😊
and just don't be panic for this update software 😉😉
08-26-2020 01:19 AM in
