A50 battery drain problem
(Topic created on: 09-27-2020 10:14 AM)
Rupesh1904
There is a 20-25% of battery drain in my galaxy A50 during night when mobile not in use
I was facing this since a week
Let me know Is there any solution to solve this problem
8 Comments
Please do battery calibration
Not applicable
if the issue is deep sleep drain i.e overnight drain then before going to sleep turn on emergency mode this is the only fix i got for m30s as issue started from last update. also send error reports hope they fix in next update.
also check this out..
https://r2.community.samsung.com/t5/Galaxy-M/Tips-to-improve-battery-life/td-p/5039156
Ehsank
one of the main reasons is even you close apps but they uses ur battery and running in background unnecessary, see image and read the statement.
2nd due to huge notification enable.
for e.g ; Google has huge notification which we don't need at all see image just scroll down image and check how many notification it does have.
So do these settings to stop, which consume unnecessarily.
1. Connection>more connections settings> disable nearby device settings
2. Location>improve accuracy >disable
A. Wifi scanning
B. Bluetooth scanning .
Ehsank
Besides above settings do some more settings to save more battery life and observe for next 1-2 days, it will give a noticeable difference
And enable these 2 options.
A. Adaptive battery
B. Put Unused Apps to Sleep.
4. Long press on each app specially 3rd party(LIKE FACEBOOK, INSTA,YOUTUBE) and rarely used apps and also ON "GOOGLE APP" as well, then click on>app info> then go to these 3 options below on by one
5. Go to settings >apps>search "weather" >click on settings icon right side > change "auto refresh" settings as per your requirements and disable some unnecessary reminder. ( due to auto refresh it continuously consuming battery?)
6. If you use Facebook frequently then disable "auto play video"
Rupesh1904
not worked........😔😔
Ehsank
did you have done all settings?
Rupesh1904
yess....but not solved
cs-member13
Expert Level 4
Dear Samsung Member,
To resolve battery issue kindly follow the below given step:-
- Battery optimization:- Settings > Select Device Maintenance/Device Care>Optimize>Optimize all options like Battery, Storage and Memory
For more information on battery drainage please click on the link below:-
http://www.samsung.com/in/support/skp/faq/1101689
If the issue still persist, kindly register your concern in Samsung Members app (Samsung Members app > Get help > Feedback > Error report/ask question). Kindly send us the screenshot (which apps are consuming most of the battery).
Note: Please send device log files within 15 minutes of issue occurrence along with the exact issue details.
