Battery problem
(Topic created on: 05-25-2025 02:45 AM)
AmeerRaza
Delhi
After updating to ui 7 my battery backup has reduced. My charging does not last for long.
4 Comments
BiRdMaN
Delhi
Yes, many users have reported experiencing similar problems. This can be due to the phone re-optimizing itself after the update or apps needing to be optimized for the new firmware.
Add apps to the "deep sleep" list to prevent them from running in the background and draining battery.
Clear app cache to remove temporary data that can impact performance and battery usage.
Resetting battery statistics can sometimes help.
Adjust background usage limits in Settings > Battery and device care > Battery > Background usage limits.
Choose options like "Put unused apps to sleep" or "Sleeping apps" to restrict background activity.
If you find this helpful, kindly accept it as a Solution. It helps others
Tap the 3 dots on my reply and select "Accept Solution." Thank you 😊
goodthings
Delhi
goodthings
Delhi
Your's most welcome to here.
cs_member10
Delhi
Dear Samsung member,
9. Reset the device:
IMPORTANT:
• For this:
