A50 battery drain and heating issue
(Topic created on: 07-29-2023 03:39 PM)
mrair
Community Guidelines
Too much draining Battery, even when It's not using then too. And it’s heating too much, even if i charge it when i turn the Phone off then too.
5 Comments
sarnandu
go to app settings turn on restrict mode for those apps which are not in use and clear Ram also
mrair
I have added some apps as deep sleep. And reset my phone couple of times but facing same problems.
sarnandu
did you turn on restrict mode
mrair
No
cs_member10
Dear Samsung member,
We acknowledge your query and apologize for the inconvenience caused to you and will surely assist you regarding the same. And please follow the easy troubleshooting steps which might help to solve the issue.
Settings > Select Device Maintenance/Device Care > Optimize > Optimize all options like Battery, Storage and Memory
Kindly turn off the smart features of the device and other connectivity features when not in use, which will eventually help you to reduce battery power consumption (smart features such as Motion gestures in advance feature and Bluetooth, Wi-Fi, Hotspot, etc.).
Please follow the below steps:
2. Tap on Bluetooth, Location/GPS, Wi-Fi, Mobile hotspot, NFC, etc. to turn off.
Please visit this mentioned link to resolve your device issue: https://www.samsung.com/in/support/mobile-devices/how-to-prevent-the-overheating-of-your-galaxy-devi...
In case the issue still occurs. Please register your concern in Samsung Members Application (Open Samsung Members Application > Support> Tap on error report > Type your query > Send).
Warm regard,
