04-01-2025 06:57 PM in
Wearables- Mark as New
04-01-2025 07:30 PM in
Wearables2. Turn Off Dolby Atmos – If enabled, it might be amplifying high frequencies too much.
3. Check for Updates – Ensure your buds’ firmware is up to date, as Samsung may have fine-tuned the audio with updates.
4. Try Different Ear Tips – A proper seal can make a huge difference in perceived sharpness and bass response.
5. Reset the Buds – If the issue persists, resetting them through the Galaxy Wearable app may help.
If the sharpness still feels excessive, it might be a tuning difference between the models. Some users report that the Buds 3 Pro has a brighter sound signature compared to the Buds 2 Pro.
04-01-2025 08:09 PM in
04-02-2025 03:18 PM in
WearablesThis issue spiked after the update, so i reset my BUDS, removed it from the phone, and again paired it.
The issue went away
04-02-2025 12:25 AM in
04-02-2025 12:32 AM in
05-07-2025 09:17 PM in
04-02-2025 05:29 PM (Last edited 04-02-2025 05:30 PM ) in
Wearables1. Adjust Equalizer Settings: Use the Samsung Galaxy Wearable app to try different presets or manually adjust frequencies.
2. Update Firmware: Ensure your earbuds are on the latest software version via the Galaxy Wearable app.
3. Reset the Earbuds: Reset the earbuds to factory settings in the app if issues persist.
4. Check the Fit: Ensure a proper fit with the correct ear tip size for better sound quality.
5. Disable Extra Features: Turn off features like "Sound Alive" that may affect sound clarity.
04-07-2025 11:06 AM in
WearablesWe apology for this issue that you are facing , could you try these steps:
Check the direction of each earbud
Make sure you are wearing the earbuds correctly
Adjust the volume of your earbuds using the device, or the earbuds themselves
Check the earbuds' battery status
Check if Ambient sound mode is enabled if you cannot hear sound well during calls
Check your phone's sound settings
Restart your phone, and then your earbuds
Check for software updates for the earbuds
If the problem persists after following these steps you need to visit the nearest service center : https://www.samsung.com/ae/support/service-center/
