Watch 4 battery problem after update
(Topic created on: 11-07-2023 11:33 AM)
PandaBeertjie
Beginner Level 3
Wearables
Hi all, please can anyone help - even @samsung.
My watch 4 went haywire after the update. First Bixby popped up all the time without me setting up anything.
Then the battery dies within 2 hrs from full charge.
Now watch does not turn on when/while charging.
Can it be fixed or did I just get a "dud" unit.
Watch is about 4 months.
5 Comments
Tendai777
Wearables
Had problems with watch 4 after update also. It says am cycling when I'm driving in a potholed area. Also no longer gives me accurate sleep tracking.
SamsungComm1
Wearables
Thank you for reaching out Tendai777
Please also factory reset your watch
Tendai777
Wearables
I did
SamsungComm1
Wearables
Thank you for reaching out PandaBeertjie
Please factory reset your watch. Ensure you have your data backed up before doing so.
If you have the Reactivation lock enabled, disable it before resetting your smartwatch.
To enable or disable the Reactivation lock:
1. On your connected device, open the Galaxy Wearable app.
2. Select Find My Watch.
3. Select Set security.
3.1. If you can't see SET SECURITY, you may need to select turn on Remote connection first.
4. Select Lock watch.
5. Select the switch to enable or disable the lock.
6. Enter a four digit PIN and select Done.
To reset your watch:
1. Press the home button on the watch.
2. Swipe down on the face of the watch.
3. Select the settings icon.
4. Select General.
5. Select Reset.
6. Select Reset again.
PandaBeertjie
Beginner Level 3
Wearables
Hi, thank you.
It is helpful, however the watch is completely dead. Does not want to charge even after a full day on the charging puk.
