Resolved! Solved
VR Headset For Note 10+
(Topic created on: 11-12-2019 11:00 AM)
Lucifeŕ
Wearables
Hello Guys !
Need your help and suggestion because I don't expect any response from SS (Stupid Samsung)
Does anyone know which VR headset is compatible with Note 10+?
As usual, Samsung has been stupid enough to end support for Virtual reality headset for Note 10 or S 10 series. So we don't have any official VR headset for S and note series. Please let me know ASAP.
Xpicey
Wearables
18 Comments
Ravi0883
Wearables
think about oculus
Not applicable
Wearables
bro even if he thinks about oculus the note 10 series doesn't have the support for any vr headsets
Ravi0883
Wearables
bhai he is also asking for S10 series
Ravi0883
Wearables
I think S10 series support VR headset though I never use
Not applicable
Wearables
no samsung has remove the support for gear vr in note 10 devices
Not applicable
Wearables
there is no support for vr headsets in note 10 as it has been removed
Lucifeŕ
Wearables
SAMSUNG Note service does support VR. I am 100% sure. Samsung has only ended service for its own Headsets. But it should work with other VR headsets from other manufacturers. I just need to know Which other VR headsets are compatible for 6+ inch screen
gakshat14
Wearables
As of now there are no option for VR. gear vr stopped working since note 9, Daydream is dead and then there are other cheap alternatives that you can always visit
Lucifeŕ
Wearables
Thanks for trying guys! I found the solution. If someone wants to know, support was ended by Samsung not by other manufacturers. so Below are the VR headsets which are working with Note 10🤩🤩🤩🤩🤩
