Samsung Galaxy Watch 7 Battery Drain
(Topic created on: 08-08-2024 11:15 AM)
Chadz
Wearables
Dear All,
Battery drain issue on my new samsung watch 7 44mm is very bad. I loose more than 50 percent of battery in sleep mode with no activity. Does anyone have any solution to this Battery drain issue ? I heard samsung USA has issued a new update for this issue, but no such updates from Samsung India regarding it.
16 Comments
Chadz
Wearables
See this screenshot, I lost 50 percent battery on sleep mode with no activity. This is after reset which did not solve the battery drain issue. 1723096496111.jpg
ArryKam
Wearables
Typical samsung issue, i fed up already. If you raise this to customer care they reply with just see time on watch and don't do anything else on it.so shame that people buying heavy price watch to see only time on it.r est abuslatoly ridiculous...
Chadz
Wearables
They asked me to visit service center. But I know this is a known bug which samsung has to fix. I have LTE variant, still waiting for that update to arrive.
ArryKam
Wearables
All the best 👍
cs_member10
Wearables
Dear Samsung Member,
As per your query, we want to inform you that We have verified that there has been occurred increase in the battery consumption of some devices on the Galaxy Watch Ultra, and Watch7.
Currently, we are working on an S/W patch to improve this situation, and we will provide an S/W update soon through the FOTA update. Please update with the latest S/W version of the device when it is available.
Aaarjun888
Wearables
Finally an explanation
balag5
Wearables
Hi,
When are we supposed to expect the fix ?
Wearables
If AOD is on in your watch turn it off and check it might improve battery life
Chadz
Wearables
Hi, It is off. Infact all functions are off still I get very bad battery life. Samsung has already responded to this thread.
