its_minhas10
09-20-2024 09:29 PM in
Wearables
This is my second post regarding #earbuds3pro.
Their is a voice and sound issue while playing #BGMIgame
After every 2 seconds, the volume goes down or sometimes completely turns off. Then, I have to press the volume button again and again to raise the volume.
2 Comments
09-21-2024 03:25 PM in
WearablesDear Samsung Member,
As per your query, we would request you kindly visit the service centre and inspect your device with the technical team end, they will provide you with all the information in a better way after inspecting the device physically.
You can locate your nearest service centre with this given link: https://www.samsung.com/in/support/service-center/
Whether it's a product repair or just some help and advice. There are authorised service centers across the IN that can help you.
its_minhas10
09-21-2024 03:50 PM in
Wearables
I just purchased the device 4 days ago. This means it's a defective device.
