MohanPTS
08-07-2023 07:17 PM in
Wearables
When I connect my samsung 25W charger with new galaxy buds2 pro, it's not charging, cany anyone please recommended or suggest me on this
6 Comments
sarnandu
08-07-2023 07:21 PM in
Wearables
15 w you can try
MohanPTS
08-07-2023 07:34 PM in
Wearables
Is 25 w charger not recommended ahh?
sarnandu
08-07-2023 07:43 PM in
Wearables
5w is recommended
you can also charge with this it is not harmful
MohanPTS
Wearables
Is 25w charger not recommended ahh?
umesh30
08-07-2023 11:46 PM in
Wearables
I think the buds should be charge with a 25W charger....!! That is no issue when you charge it with 15w 25w or higher than, The Galaxy Buds will not suffer any damage because its motherboard design is like this.
Phoenix10
08-31-2023 06:38 PM in
Wearables
Even if you use a 25W charger the Buds will charge at 5W only since it's the supported wattage. But be sure to use a Samsung charger or a PPS enabled charger from a reputed brand to avoid any damage to the buds. I use 25W Samsung charger and it chargers the buds fine.
