Buds2 Pro connection issues with Samsung wearable
(Topic created on: 12-19-2024 06:33 PM)
khatokar
Wearables
I have purchased Samsung Buds2 pro it got connected to Bluetooth normally but with Samsung wearable it is not getting connected and I am not able to reset it also, does anyone else also facing this issues?
2 Comments
cs_member8
Wearables
Dear Samsung Member,
As per your concern, we would request you to kindly perform the following steps to connect the buds with your device.
Note: Bluetooth must be enabled on your Galaxy smartphone.
Step1: Place earbuds in the case and close the lid.
Step2: Open the case to enter into pairing mode.
Step3: Tap ‘Connect’ and follow the on screen prompts.
Step4: Go to ‘Galaxy Wearable’ app on your mobile device then tap ‘Start’.
Step5: Enable your device location services to find, connect to your device and determine the relative position of nearby devices. Select location permissions.
Step6: Select your Galaxy earbuds.
Step7: Tap ‘Pair’.
Step8: Tap ‘Continue’ to agree to the ‘Samsung End User Licence Agreement’.
Step9: Grant app permissions.
sumit227
Wearables
Not solved
