Battery 🔋 drain problem
(Topic created on: 08-05-2025 06:34 PM)
Aryan510
Wearables
My newest ️ 8 40mm gives hardly one day of battery backup.any solution suggest please
5 Comments
Kaustav_Ray
Expert Level 3
Wearables
Reduce brightness, disable AOD, limit background apps.
Kaustav_Ray
Expert Level 3
Wearables
If this helps, please accept it as a solution. Click the three dots on my reply and select 'Accept Solution.' Thanks!
Follow me more information.
Aryan510
Wearables
I tried already but did not get an effective impact. Thank you.
cs_member10
Wearables
Dear Samsung Member,
As per your concern, we would request you kindly perform the following steps to resolve the battery-draining issue.
There are several reasons why your Galaxy Watch may be experiencing battery drain or have decreased battery life.
For example, certain apps can increase battery consumption.
● Inspect the watch and charger for physical or liquid damage.
● Use only Samsung-approved chargers and accessories, which are specifically designed for the device. The Watch cannot be charged properly with a third-party charger.
Follow the given tips to resolve the battery draining issue:
1: Perform a diagnostic- If your watch is paired with a Samsung phone, you can use Samsung Members to perform a diagnostic on your watch battery. If it passes the test, you'll know the battery is in good condition.
2: Update your apps: Sometimes apps may have a bug that causes them to use excessive battery, make sure all your apps are up to date for the best performance.
3: Update your software.
● From your phone: Galaxy Wearable app > Watch settings or SETTINGS > About watch > Update watch software Or tap About Gear > and then tap Update Gear software.
● Tap Update now or Download updates manually, and then follow the on-screen instructions. If desired, you can choose to automatically update the software by turning on Auto update or Download updates automatically. The watch will disconnect during this time.
● After checking for software updates to your watch, check if any updates are available for apps installed on your watch.
4: Turn off unused health trackers.
Sleep: Tap Settings at the bottom of the menu, turn the switch off, and then tap OK to confirm.
Heart rate: Tap Auto HR Settings from the bottom of the menu, and then tap Never.
Stress: Tap Auto stress settings from the bottom of the menu, and then turn the switch off.
5: Delete data and close background apps.
Note: These steps do not apply to the Galaxy Fit.
From your phone: Galaxy Wearable app > Watch settings or the SETTINGS tab > About watch or About Gear > Storage > CLEAN NOW, > tap the Back (<) icon > RAM > CLEAN NOW.
6: Turn off network connections.
7: Turn off Watch always on.
8: Turn off voice wake-up in Bixby or Google Assistant.
9: Customize your notification settings: From your phone- Galaxy Wearable app >Watch settings or the SETTINGS tab > Notifications > Advanced notification settings > switches > Show with details and Turn on screen.
10: Turn on power saving mode: Press the Home key (Power key) on your watch, > Settings > Battery and device care > Battery or Battery management > switch next to Power saving.
11: Do not expose your watch to temperature extremes: Exposing your watch to very cold or very hot temperatures can shorten the watch's battery life and could lead to damage.
Aryan510
Wearables
Thanks a lot. 🙏
For your helpful tips .
