BUDS3PRO connectivity issues
(Topic created on: 11-14-2024 09:27 PM)
MKNote20Ultra
Wearables
Even though I've selected the "seamless connection" activated in the settings, my Buds3Pro do not switch automatically between my phone & windows laptop (running latest versions). Any advise?
2 Comments
ŠůmèəȚ
Wearables
Seamless Connection with Auto switching support is only available on Samsung phones and tablets, and Samsung TVs from 2022 and later.
https://www.samsung.com/us/support/answer/ANS10002627/
cs_member10
Wearables
Dear Samsung Member,
● First, make sure the other device is turned on. Then, navigate to and open Galaxy Wearable on your phone.
●Tap the Menu icon (the three vertical lines) in the upper left-hand corner.
●The name of the most recent device (Example: Galaxy Watch Active2, Gear S3, etc.) will appear at the top of the list.
●Select the device you want to connect to, and the app will automatically connect.
Note: Keep in mind that Galaxy devices running One UI 3.1 or above must be signed in to the same Samsung account to use this feature.
If still facing issue, kindly reset the buds once and try again later.
Path: Step1: Kindly open Galaxy Wearable App.
Step2: Tap on about earbuds.
Step3: Reset earbuds.
