face id issue and dialler issue
(Topic created on: 11-21-2017 10:10 PM)
changzi
UDS
i think i made a mistake that i bought S8. its a shitty phone sometimes face lock does'nt work and dialler is pathetic
2 Comments
AnkurBansal
UDS
Don't use face recognition. I would suggest ypu to rather use IRIS scanner. It is more reliable and works well in dark and lit areas.
About dialler, I don't know how you are finding it bad but it has all the option one needs( except call recorder). Please describe your issue with dialer.
admin_
UDS
Thank you for your query. The relevant department may serve you better/speedily, if you can provide logs/video by registering this feedback in Error Section (Samsung Members App -> Feedback -> Questions/Errors -> Create -> Error reports). Be sure to hit ♡ when you find an answer that works for you.
