tap tap Gestures
(Topic created on: 02-07-2021 04:06 PM)
Titu911
Tech Talk
Double tap the back of the phone to turn on the flash light
Triple tap the back to take a screen shot
9 Comments
Abhishek13892
Tech Talk
In Android 11 we would get thats, as per current tech news
A-
Tech Talk
This is will be considered if your phone hardware supports it.
Simply A Software update cannot help you have this features in your phone.
Anikroyale
Tech Talk
Most devices do support it. It works in my M31s using an open source software called Tap Tap. It uses some sensors which are present in 99% of devices.
A-
Tech Talk
That's pretty cool 😃
I didn't knew about it ..
Ehsank
Tech Talk
what you suggest will make a mess with mobile , and for S S Enable assistant menu, this is best way ,by this option you can also perform other important task such as screen off, navigation, sound, screen rotation, power off menu, notification panel and also specific app option available
To enable assistant menu just go to
settings>>accessibility >>interaction and dexterity>>assistant menu>>enable and also click on it and enable>> assistant plus menu
kumar6789
Tech Talk
As per current reports Android 12 will support it.
