network problem in galaxy M31
(Topic created on: 03-28-2020 05:29 PM)
megamonster
Tech Talk
Iam using Vodafone sim in mobile..this is the fastest 4G network in my area..after starts to use this mobile, iam facing network problem very badly while others getting good network speed in the same network ..i tested my sim with other mobile and internet is very fast in my sim.The problem is not only in mobile data speed,but also in WiFi internet speed..while othe mobile the wifi is getting with full speed.. But my mobile (m31) is not Accessing that much internet speed.. Even I'd reset my phone phone twice...but no use of it.
184 Comments
Samsung_A9ArSjB
Tech Talk
I bought M31 in January 2021 and facing same problem ,internet is not working on Airtel SIM card.
Samsung_BbAw7vL
Tech Talk
Its still not working .
mrityunmidya
Tech Talk
I am also facing the same problem. Samsung Authority must fix the "slow network" problem as soon as possible.
bauva123
Tech Talk
absolutely right
Alphamarak
Beginner Level 4
Tech Talk
Problem not solved
Hish2
Tech Talk
I also facing this issue
Nirjar
Tech Talk
Not working
Denisono
Tech Talk
im at tesco and had same issues for last 2 weeks. tried this and its flying
settings_connections_mobile networks_acces point names then tap on your carrier and on the next window change autentification type_ from none to POP and CHAP then chose ipv4/ipv6 both APN CONTROL and APN roaming then tick in BEARER every each you have in the list except unspecified
i would attach some pics but no option for that
try this . should sort out the problem
good luck
nash000
Beginner Level 4
Tech Talk
Thank you Denisono. The issue is now resolved.
