bluetooth sound quality issue
(Topic created on: 10-25-2020 01:39 PM)
Nilu4367
Tech Talk
As per tech suggestions i have used developer mode to change bluetooth setting for better enhancement of audio player output. Like codec LADC and Stero sound etc. But setting goes back to default mode as soon as i come out it. Why every time i have to change it ? Why its not stable ? Pls help and suggest.
2 Comments
Tanmay8102
Tech Talk
It also depends on your Bluetooth Headsets that Which Codec is Supported.If Suppose My Bluetooth Headset is supports AAC/SBC and I wanted to change to LDAC then it is not possible to change because my Headset doesn't supports LDAC.
cs-member13
Expert Level 4
Tech Talk
Dear Samsung Member,
We apologize for the inconvenience caused to you. We request you kindly visit the service center for the physical inspection of your device. To check for the nearest Samsung service center kindly click on the link:- https://www.samsung.com/in/support/service-center/
