USB THREADING Problem
(Topic created on: 01-03-2020 07:55 PM)
RjSandy
Tech Talk
I attached my A50s with PC through original USB cable for sharing Internet through selecting USB THREADING Option.....but alas! it cannot be possible to connect with PC by some means which I don't know exactly.......
Can anyone  suggest me the reason..... and how can the connection be done ???
3 Comments
Tech Talk
after connecting to your PC, u must be getting a pop up on ur mobile screen as charging only and data transfer. u need to select the data transfer option. and then it will start working. in case u will face any other issue please respond.
Tech Talk
Hi there,
Please perform the following steps to resolve the issue:
>Perform Interactive checks through the Samsung Members app (Samsung Members> Get Help> Interactive checks->charger/USB).
>Kindly check by using any other USB cable and also  USB cable in any other P.C port.
>Go to the device settings > developer > USB debugging > enable it.
>Reset the device settings by navigating to Settings >> General Management >> Reset >> Reset Settings.For further assistance, register your concern in Samsung members app(Open Samsung members app>click on “+“icon>send feedback>Error report/ Ask Questions).
Regards,
Team Samsung Members
RjSandy
Tech Talk
Thanks all of you for your valuable suggestions......
My problem has solved now....
