Top 10 Samsung Note 10+ Camera Tips and Tricks to Click like a Pro ...
(Topic created on: 10-22-2019 09:28 PM)
Webstallion
Tech Talk
The Samsung Galaxy Note 10 Plus features an array of cameras. Right from an ultra-wide and wide lens to a telephoto lens and a DepthVision camera, it is armed with capable lenses as well. The AI smarts of Snapdragon 855 backs the camera department. Yep, the Galaxy Note 10 and Note 10 Plus can click excellent quality pictures. The good news is that you can make them great by tweaking a couple of features and settings.
In this post today, we will show you all the camera tips and tricks of the Samsung Galaxy Note 10 and Note 10 Plus.
As it's going to be a lengthy post, let's jump straight to it.
1. SCENE OPTIMIZER
The Scene Optimizer is one of the most recent additions to the Galaxy Note series. As suggestive of its name, it's an AI function, which helps boost the photo quality by studying the object and doing the appropriate changes.
To enable Scene Optimizer, go to the Camera Settings (tiny cog-shaped icon at the upper-left side) and toggle the first switch.
Best Samsung Note 10 10 Camera Tips And Tricks 1
After that, you'll see a blue icon come to live whenever you'll aim your camera at an object. Within a split of a second, it'll recognize the object and apply the necessary changes.
PRO TIP: Having trouble framing your shots? Why not let the AI handle it? Enable the Shot Suggestions option in the camera settings and wait for the AI fun to begin.
2. SUPER STABLE MODE IN VIDEOS
Shaky Hands? Why not let the camera do the job of stabilizing your videos? The Note 10 comes with a Super Steady Mode for video recording, which brings software-based stabilization thus ensuring smother and shake-free recordings. It is available for the wide-angle lens and the primary lens.
To activate it, open the video mode and tap on the little hand icon at the top. So, all you need to do is record your shake-free videos.
Best Samsung Note 10 10 Camera Tips And Tricks 14
Note that it is limited to 1080p in 30fps videos.
3. SAVE AS HDR10+ VIDEOS
Like the Samsung Galaxy S10, the Galaxy Note 10 and 10+ also support HDR10+. That is a high dynamic range format that helps you get richer and more life-like videos by optimizing the color and contrast.
Best Samsung Note 10 10 Camera Tips And Tricks 5
Best Samsung Note 10 10 Camera Tips And Tricks 6
To enable it, go to the Camera settings and select Advanced Recording Options. Next, select HDR10+ video. Note that since it's an experimental feature, you might not get the same result every time.
4. UTILIZE THE ZOOM-IN MIC
Another labs feature which makes its debut is Zoom-in mic. As suggestive of its name, it zooms in to the noise, thereby amplifying the audio and drowning out other background noise.
Best Samsung Note 10 10 Camera Tips And Tricks 7
The setting hides under the Advanced Recording Options. All you need to do is toggle the switch on.
5. NIGHT MODE AND ULTRA-WIDE
Now, a little bad news. The combination of the Night Mode and the Ultra-wide Mode isn't that great in the Note 10 Plus. Though you will get a wide-angle shot, the quality will be a tad grainy with plenty of noise.
Best Samsung Note 10 Plus Camera Tips Tricks 1
Night Mode + Ultra-Wide
Best Samsung Note 10 Plus Camera Tips Tricks 5
Night Mode
Hence, the best option is to click a normal picture in the night mode.
DID YOU KNOW: The Note 10 comes with a cool AR Doodle feature.
6. ULTRA WIDE SHAPE CORRECTION
The wide-angle lens of the Galaxy Note 10 is great to capture wide vistas. But as wide-angle lenses go, they can give a fish-eye look, especially if the frame has buildings or any other straight structure on the sides.
Best Samsung Note 10 Plus Camera Tips Tricks 2
Thankfully, the Galaxy Note 10 comes with a built-in option to make these corrections. However, Samsung does not enable it by default.
Best Samsung Note 10 Plus Camera Tips Tricks 3
To make these changes, go to Settings and scroll down until you see Save Options. Next, select Ultra Wide Shape Correction.
Best Samsung Note 10 10 Camera Tips And Tricks 4
Best Samsung Note 10 10 Camera Tips And Tricks 3
COOL TIP: Love shooting in Pro Mode? If yes, toggle the switch for RAW images under Save Options.
7. EDIT MODES
Would you like a clutter-free camera interface? Not every camera mode finds use in day-to-day life. At most time, you'll find that the Night Mode, Live Focus, and Food Mode are more used than the others. After all, who can resist clicking a picture of a delicious looking plate of spaghetti with meatballs?
Anyways coming back to the point, if you are looking for ways to declutter the camera interface, there's a way. Go to Settings > Camera Modes > Edit Modes, and uncheck all the modes that you don't like.
Best Samsung Note 10 10 Camera Tips And Tricks 8
Best Samsung Note 10 10 Camera Tips And Tricks 10
And while you are at it, you can also rearrange the different modes as per your convenience.
