Solution to Slow Network Problem
(Topic created on: 10-06-2021 06:23 PM)
SulochanaKumariNoDMs
Tech Talk
Hey! Many of you are facing slow network problem. Follow the following steps to overcome this problem:
Go to: Settings > enable "Developers option" by clicking on it > click on "Build Number" 7 times, then enable "Wi-Fi Scan throttling" by moving toggle towards right. This saves battery & improves network performance. Hope this solves your problem. See the screenshot given above.
5 Comments
Edwin7878
Tech Talk
I think this is only good at improving wifi network performance..
Most of the people are fine with wifi networks but still there are some range issues I think ..
The problem is mainly with mobile data network bro rather than wifi ..
But this setting is useful 👍👍
Tech Talk
My M21 doesn't have any network problem.
Compared to other Samsung devices in my home, my M21 gets faster mobile data speed(BSNL 3G).
But my phone battery drains by 10-15 % overnight.
But when I try Flight mode, my phone battery drains 0% full night.
Can't understand why is this problem 😔
Tried factory reset too 2 weeks ago.
This problem started just after updating my device to One UI 3.0.
Edwin7878
Tech Talk
Yes bro I too faced same issue on my m51 after android11 update .
6-7% used to drop on that time ..
Now it is almost ok ..
May be due to any optimisation issues sent error report bro ..
Also puting flight mode is not that good in case of any emergency call incoming..
Try to put it on maximum power saving mode and try
Tech Talk
Check if some background apps are draining your battery. If so, then optimize/hibernate/disable them.
Tech Talk
Its mainly used for Power saving
