Solution Battery Drain One UI4 πŸ“ŒπŸ“Œ
(Topic created on: 01-14-2022 09:25 AM)
RahulMangla
Tech Talk
Have you checked in Device Care after a full cycle to see if an app is using more battery than normal? You can run the optimise programme in that program too. After an update, if a phone is still misbehaving after a few days, which allows all the files etc to settle, the first thing I'd try is to clear the phones system files cache.πŸš€
Clear the stored data in your system's memory cache. You might need to hook up to a computer or insert your headphones to get to the recovery menu.https://www.samsung.com/uk/support/mobile-devices/how-do-i-clear-the-cache-on-my-device/ If that doesn't help, try safe mode.πŸ–₯https://www.samsung.com/uk/support/mobile-devices/how-to-start-my-galaxy-device-in-safe-mode/
Some Helpful tips for battery DrainπŸ₯https://youtu.be/o32KO_fDQVs
disables downloaded apps, themes, and other startup programs to determine if one or more conflicts are causing it. Full charge your phone and then use it until it shuts off.swtich on Phone use it untill turn off the screen and then press both buttons together.
And check out the battery reset fix video.
do the sameπŸ˜‘
https://youtu.be/gbgLLeLN4iI
Hope this solution works for you
Like and share
And comment if anything left
KISANRAO
Tech Talk
I like it
