Battery Drain
(Topic created on: 08-21-2024 05:11 PM)
gogunag
Tech Talk
In samsung s23fe battery drain issue not resolved
In last night I have 25 percentage, in the morning,I when I see my phone already got switched off 😒
Any solution?
4 Comments
nike007hs
Tech Talk
S22 plus I'm facing same thing right now I have charged my phone 5 h 10m ago and with 1h 1m screen on time, my phone has consumed 37% battery.
gogunag
Tech Talk
Tech Talk
Bro same problem 😪
cs_member10
Tech Talk
Dear Samsung Member,
As per your concern, we would request you kindly perform the following steps to resolve your issue by the given links.
Galaxy device Battery drain issue: https://www.samsung.com/in/support/mobile-devices/how-can-i-optimise-and-extend-the-battery-life-on-...
You can reset your device by following the steps.
If the issue still occurs, please visit the service centre for a physical inspection of your device. You can locate your nearest service centre with this given link: https://www.samsung.com/in/support/service-center/
