Resolved! Solved
Samsung Tips- Solution for all problems
(Topic created on: 08-26-2021 12:33 PM)
Not applicable
Tech Talk
Have you been getting confused for the purpose of any feature or how to use it?
Samsung Tips help you finding thise solutions, it is basically for beginners and for those who recently switched to Samsung.
It also helps getting one to one solution by Technical Support. Although this app varies from phone to phone and software. But here are some basic tips which may help you, know your phone better.
You can also download this app from Galaxy Store or if not supported then ApkMirror.
1) Samsung Tips
2) Go Beyond
3) Manage your phone's
 settings
4) Keep your phone secure
5) Be more productive
6) Do more with Notes
7) Link your phone to your
 PC
8 ) Get to know Bixby
2 Solutions
Tech Talk
Tech Talk
Pretty long image post! Tired 😩 while scrolling!
Bty it's a really helpful post for beginners!
13 Comments
Not applicable
Tech Talk
Samsung Tips is only available in few devices. If your device didn't supports, install from ApkMirror.
If have any more questions, you can ask here.
Also the quality of the image has been decreased by Samsung Members, so you can see full quality images here-
https://linksharing.samsungcloud.com/vqeFf5L6sqjT
Not applicable
Tech Talk
Not on core 😢😢
Not applicable
Tech Talk
Yes, not for Core Devices.
Not applicable
Tech Talk
Why Samsung did this 😔
Not applicable
Tech Talk
Where are you?
Not applicable
Tech Talk
Sleeping 😴🛌
Tech Talk
Not applicable
Tech Talk
OK!
