Resolved! Solved
Samsung M31 Audio Problem
(Topic created on: 07-15-2020 06:03 PM)
RyZo
Tech Talk
I just got my phone like 2 days ago. I havent faced any problems or anything (except this). So, if I'm on a call with someone or I'm using Zoom or Google Meet, all the audio coming from the phone sound terrible. like YouTube or Spotify sound really bad.
I have really good internet and I've tried this with and without headphones. Sometimes the call itself sounds bad and sometimes the call is fine.
PLEASE FIND A FIX.
Tech Talk
plz check it in safe mode. if issue continues its hardware problem. otherwise the issue of any apps installed. try that
30 Comments
Diablo2212
Tech Talk
speaker is bad yes
RyZo
Tech Talk
yes the speaker is bad but that's not my biggest problem, the audio from the headphones and music sounds bad when I'm on a call, and if I'm not on a call it sounds perfect
Diablo2212
Tech Talk
i will try my JBL tune 500 and revert
RyZo
Tech Talk
thank you so much
tell me what you find
Tech Talk
are you using any third party apps like call recorder??
RyZo
Tech Talk
no, I'm not using any third party apps (I think)
RyZo
Tech Talk
do you think I have a defective piece? should I get an exchange? there aren't any problems besides the audio quality being very bad during calls
ami9611
Tech Talk
Very poor call quality , not able to hear correctly and vice versa.. I suggest not to go for Samsung any of the products
Tech Talk
