Samsung Flow issue
(Topic created on: 01-20-2025 12:42 PM)
royo1e
Tech Talk
Samsung flow not working on Wi-Fi. It used to work before. I tried to connect with Bluetooth it connected but file share getting failed. Only works with USB cable. I re-install for both but issue remain same. Any solution!!
cs_member10
Tech Talk
Dear Samsung Member,
We also request you kindly share the log file. Also, share the video clips and images for better understanding. This will help us to investigate further and resolve this issue.
To share the log file: Open Samsung Members Application > Support> Tap on send feedback> Choose Composer> Select error report> Select the appropriate issue category> Type your query and send.
