S24 Ultra Battery Performance/Heating Issues
(Topic created on: 03-07-2024 01:23 AM)
Amit2402
Beginner Level 5
Tech Talk
Hey Everyone,
I have bought a new S24 Ultra. After using it for almost a week I observed that it's battery is draining very fast. Moreover it is charging very slow even with 45W charger. But that was not the case before 1st week of usage. It was charging very quickly and was giving good battery backup. Now it has some heating issues as well. I am not sure what could be the possible reason for that. Can anyone please suggest me if this is same for everyone else or what could be the solution to fix this. Any recommendations would be greatly appreciated. Thanks in advance.
8 Comments
Syed29
Tech Talk
Did you try resetting your device? If the issue still persists then please visit the service center
Amit2402
Beginner Level 5
Tech Talk
Yes already did multiple times.
Ultra_Devil
Tech Talk
Hey Amit, check my recent post for battery performance optimisation.. you will thank me later.. 😉
goodthings
Tech Talk
Your's device is very new, so please wait for some time and give it some time for better performance. So please don't bothered about this. If you like please accept as a solution it's help to others users also, click 3dots in my reply section and click on accept solution. Thanks.
goodthings
Tech Talk
Your's most welcome to here.
goodthings
Tech Talk
Congratulations for your AI S24 Ultra. Thanks.
cs_member10
Tech Talk
Dear Samsung Member,
As per your concern, kindly follow the given steps to resolve your issue.
Galaxy device heating issue: https://www.samsung.com/in/support/mobile-devices/why-the-device-heats-up-during-use/
Fast charging: https://www.samsung.com/in/support/mobile-devices/my-galaxy-device-is-not-fast-charging-how-do-i-fix...
For battery drain issue we want to inform you that when you initially use the terminal, the battery consumption may be rapid due to learning battery usage patterns and application of performance optimization. It will stabilize after a certain period, but if you still have problems, kindly visit a service center.
You can locate your nearest service center with this given link: https://www.samsung.com/in/support/service-center/
JithinAjith
Expert Level 3
Tech Talk
Settings 》Google 》Devices 》Turn off scan for nearby devices
Settings 》Connections 》More connection settings 》Printing 》Turn off default printing service
Device care 》Battery 》Background usage limit 》Deep sleeping apps 》 add apps
Settings 》Location 》Improve Accuracy 》Turn off Bluetooth and WiFi scanning
