Power drain
(Topic created on: 10-22-2020 02:58 PM)
SantyBala
Tech Talk
My galaxy a50 phone loses over 12 to 15%battery at night.There is no third party application running on the phone and I had never installed any till date.Is it because of the recent update?
7 Comments
KabeerV
Tech Talk
Did you check the battery usage statistics as to which app is draining the battery??
SantyBala
Tech Talk
yes,I turned off every apps background data and the only app which runs at night is samsung mini but even it takes 0.1%
Ehsank
Tech Talk
one of the main reasons of battery drain is even you close apps but they uses ur battery and running in background unnecessary, see image and read the statement.
2nd due to huge notification enable.
for e.g ; Google has huge notification which we don't need at all see image just scroll down image and check how many notification it does have.
So do these settings to stop, which consume unnecessarily.
1. Connection>more connections settings> disable nearby device settings
2. Location>improve accuracy >disable
A. Wifi scanning
B. Bluetooth scanning .
Screenshot_20200909-020608_Settings_60630.jpgScreenshot_20200731-222607_Settings_58499.jpg
Ehsank
Tech Talk
Besides above settings do some more settings to save more battery life and observe for next 1-2 days, it will give a noticeable difference
And enable these 2 options.
A. Adaptive battery
B. Put Unused Apps to Sleep.
4. Long press on each app specially 3rd party(LIKE FACEBOOK, YOUTUBE) and rarely used apps and also ON "GOOGLE APP" as well, then click on>app info> then go to these 3 options below on by one
5. Go to settings >apps>search "weather" >click on settings icon right side > change "auto refresh" settings as per your requirements and disable some unnecessary reminder. ( due to auto refresh it continuously consuming battery?)
6. If you use Facebook frequently then disable "auto play video"
7. Google >click on 3dot>usage and diagnostics >off this option.
SantyBala
Tech Talk
thank you very much
Ehsank
Tech Talk
if my given settings/comments will work for you then you can accept as solution by CLICKING on 3DOT at my comments
cs-member13
Expert Level 4
Tech Talk
Dear Samsung Member,
We apologize for the inconvenience caused to you. To resolve battery issue kindly follow the below given step:-
- Battery optimization:- Settings > Select Device Maintenance/Device Care>Optimize>Optimize all options like Battery, Storage and Memory
For more information on battery drainage please click on the link below:-
http://www.samsung.com/in/support/skp/faq/1101689
If the issue still persist, kindly register your concern in Samsung Members app (Samsung Members app > Get help > Feedback > Error report/ask question). Kindly send us the screenshot (which apps are consuming most of the battery).
Note: Please send device log files within 15 minutes of issue occurrence along with the exact issue details.
