07-31-2020 05:28 PM (Last edited 01-24-2021 04:48 PM ) in
Tech TalkWhile charging the device, device seems to heat up. Why is this?
Do the following when the device heats up:
• Disconnect the charger from the device and close any running apps. Wait for the device to cool down and then begin charging the device again.
• If the lower part of the device overheats, it could be because the connected USB cable is damaged. Replace the damaged USB cable with a new Samsung-approved one.
• When using a wireless charger, do not place foreign materials, such as metal objects, magnets, and magnetic stripe cards, between the device and the wireless charger.
NOTE: THIS IS A FAQ FROM SAMSUNG GET HELP SECTION. I SHARED ONLY TO HELP AND INFORMED YOU ALL.
