Issue In Wifi Speed
(Topic created on: 09-03-2020 06:23 PM)
yashchhatrala
Tech Talk
I have Samsung A6+ device (SM-A605G/DS). I have issue in my phone since last 6-7 days. I have 4 MB/s wifi plan. But i got only 1-1.5 MB/s speed in my phone. I checked my router but there's no issue bcoz I checked in other mobile phones & laptop, in this i got 4 MB/s speed. But i can't get in my phone. I reset my APN settings & also reset my network settings. After that i got speed for an hour. But after hour again same low speed as before. What is problem in this ? Please suggest any solution of this. Thanks in advance.
13 Comments
Ehsank
Tech Talk
always companies refer maximum speed , that's doesn't mean to you will get that speed as claim.
besides this if more than one network shared the wifi then its divided the speed naturally
Ehsank
Tech Talk
however you can try these settings
go to settings > General Management >reset>reset network >and in your router also reset once
then try
yashchhatrala
Tech Talk
Yes but i checked multiple times in multiple devices for speed, they got maximum speed. & I'm only user of wifi.
I reset network settings. after that i got maximum speed for an hour. but after hour, speed is low as before.
Ehsank
Tech Talk
they got in your area?
may be location issue🤔
yashchhatrala
Tech Talk
Yes, in my area. Got max speed in all of them. but not in my device.
Tech Talk
How you are checking the speed?
yashchhatrala
Tech Talk
Using various speed test sites.
Tech Talk
okay here is the thing if you have One UI 2.0+.
Goto WiFi and Follow the screenshots to turn off WiFi power saving mode and try..
Tech Talk
