How to change battery low notification sound
(Topic created on: 11-20-2021 07:31 PM)
jayjazz
Tech Talk
Can anyone show way to change low battery notification sound!! I  hope i get help here😇
7 Comments
Tech Talk
Which device.?
jayjazz
Tech Talk
Mine samsung note 10 lite!!
Tech Talk
It can be changed but rooting is not recommended 😞
Tech Talk
THAT ARE SYSTEM SOUNDS CAN'T BE CHANGED FROM SETTINGS
SELECTED IN ROOT OF ANDROID OS
jayjazz
Tech Talk
sammy25
Tech Talk
If your device support Bixby routines, you can make a custom routine for it.
Else you have to change system notification sounds which are in limited numbers.
Tech Talk
Dear Samsung member,
Thank you for sharing your concern. And please follow the easy troubleshooting steps which might help to solve the issue.
1 Head into your Settings > Apps.
2 Tap on an app you would like to customize the Notification tone.
3 Tap on Notifications.
4 Select a category you would like to customize.
5 Ensure that you have selected Alert then tap on Sound.
6 Tap on a sound then presses the back button to apply changes.
In case the issue still occurs. Please register your concern in Samsung Members Application (Open Samsung Members Application > Get help > Send Feedback > Error report/Ask questions).
