[ Guide] Common Problems Users are facing
(Topic created on: 12-23-2022 09:21 AM)
YashAgarwal
Tech Talk
Hi everyone recently Multiple Devices got OneUI 5 Android 13 Update. This a major OS Update so it's recommended to reset your device once after updating so that everything will be cleaned and New OS data will be applied properly.
You can take your data backup via Smart Switch on PC. Just don't take backup of your apps and settings only take backup of your data and once setup restore everything.
Now talking about 5G multiple devices got updates for 5G but still I'm not sure from which end the issue is that show 5G is not supported.
So I think for proper 5G service you need to wait for next year end so that both companies will roll out everything properly.
I see some posts users are facing regarding storage issue after Updating in that case reset is required.
For Performance issue solved I've posted multiple guides on this you can check also with new OS Samsung Introduced RAM+ I've noticed that if you set it to 4gb you'll face problems like heat or lag , on 2gb you'll get better battery and on Max like 6gb ,8gb you'll get a proper balanced performance. If you turn it off you'll see some lags even on OTT PLATFORM videos will lag if you turn it off. So its tested by me multiple times on multiple devices to I recommend it to set it max.
Having any query you may comments here or in DM I'll try my best to give you best possible solution as always I do.
Thanks you for reading.
Happy Holidays everyone and be safe.
Sid_Karna
Tech Talk
Ok bro
Tech Talk
That's something odd caz I've set it to 2gb if you want better battery in my case on 4gb its worse on 6gb and max its perfect.
rush20
Tech Talk
Didn't improve performance but it's now more laggy.
I have reset it to 2gb now
Tech Talk
If you're OneUI 5 you can turn it off also without adb test it that way too.
Sid_Karna
Tech Talk
Ic... It's working differently for different people strangely. I have been using it at 2gb since a long time. I didn't find any change between 4gb and 2gb.... both were smooth in my case.
rush20
Tech Talk
Yeah animation got slow and yotube lagged more on 6gb. On 2gb everything works fine just youtube lags in landscape view(don't know why)
ㅤ
Tech Talk
If there is no other app used (except one u r using). ... and that specific app is lagging... that means there is no relation of Ram.
rush20
Tech Talk
Background mai network meter,accubattery,routines,health app chalta hai rehta hai🤔
ㅤ
Tech Talk
No no no....
That are just background processes.. bg processes dnt use too much ram..
For eg. In my device 2.5gb ram is always used of total 4gb. If i delete health app, and some other too. Stilllllll device will be at 2.5gb.😝
rush20
Tech Talk
Oh OK 👍
Then the problem is with phok youtube🤕
