Charging battery issue
(Topic created on: 04-12-2020 05:01 PM)
AlluMadhan
Tech Talk
Hii.. I am using Samsung m30....i am getting notification like USB connected after 2sec disconnected continuously... Now phone is also not getting charged.. When I turn off the phone it gets charged... When I turn on it is not getting charged.. I tried with different charger and cable.. No use... Please help me what to do🙏
6 Comments
neranj
Tech Talk
perform factory reset bro
AlluMadhan
Tech Talk
Will it work??
AlluMadhan
Tech Talk
I work it in safe mode also but no use..
Samsung_Support4
Tech Talk
Dear Samsung Member,
Please perform the below mentioned step to resolve the issue:
1. We always recommend to use genuine Samsung charger for charging your device.
2. Check your charging cable (USB cable) for physical damage such as wear and tear, bent prongs etc. If it is damaged then kindly visit your nearest service center to get it replaced.
3. Check charger functionality, try to charge your device with some other charger or use your charger to charge some other device.
For further assistance, register your concern in Samsung Members Application (Open Samsung Members Application > click on “+“icon > send feedback > error report/ask questions).
Samsung Customer Suppor
Suba456
Tech Talk
We are getting the above said notification when the usb type c cable is not connected to the phone.
AlluMadhan
Tech Talk
now my phone is not getting charged at all😭😭😭😭
