05-18-2020 11:20 AM in
Tech TalkI have bought the Samsung a10s from nepal in 2020 , 21 March and now its battery is draining too fast can you update the software.
Solved! Go to Solution.
05-20-2020 07:34 PM in
Tech TalkDear Samsung Member,
We at Samsung understand your concern. Kindly follow the below mentioned step to improve the performance of the device
- Perform Battery Optimization: Settings>> Select Device Maintenance/Device Care>> Optimize>> Optimize all options like Battery, Storage and Memory
- Adjust screen timeout settings: Settings>> Display>> Screen timeout>> Select minimum screen timeout.
If the issue still persist, we would request you to please contact your local subsidiary for better assistance. Please follow the below mentioned toll free number:
+977 9801572667(For NTC Customers Only) | 8A.M to 8P.M| 7 Days a week
10-13-2020 09:39 AM in
Tech Talk
