Battery Draining Problem
(Topic created on: 11-05-2020 08:04 AM)
Azeef_Muhammed
Tech Talk
My Samsung Galaxy A20 drain battery after 30% without any use I noticed this problem before 3 months and replaced the battery from the authorised service centre but still the problem is here someone please help me I'm totaly disappointed
10 Comments
Ehsank
Tech Talk
do some settings to save more battery life and observe for next 1-2 days, it will give a noticeable difference
1. Connection>more connections settings> disable nearby device settings.
2. Location>improve accuracy >disable
A. Wifi scanning
B. Bluetooth scanning .
And enable these 2 options.
A. Adaptive battery
B. Put Unused Apps to Sleep.
4. Long press on each app specially 3rd party app(LIKE FACEBOOK, YOUTUBE) and rarely used apps and also ON "GOOGLE APP" as well, then click on>app info> go to these 3 options below on by one
6.  Go to settings > Google > on device sharing> check which 3rd party apps present there for e.g. if you use paytm , paytm will  shared data to show recommendation and suggestion which also cause battery drain
7.  Go to settings > account and backup> account > check which app syncing automatically there, and if any app which not necessary to auto sync then click on it and "disable sync"
8. Go to settings >apps>search "weather" >click on settings icon right side > change "auto refresh" settings as per your requirements and disable some unnecessary reminder. ( due to auto refresh it continuously consuming battery)
10. Google >click on 3dot at right top corner>usage and diagnostics >off this option.
Tech Talk
All are done but still after 30% my phone switch off automatically
Ehsank
Tech Talk
as you said just at 30% its happened, so go to safemode just before 30% and observe is there same issue in safemode too
if same issue in safemode then try to visit service centre it may be a hardware issue
steps to turn safemode;
long press on power button>
long press on power off option>click on safemode >your mobile will restart and turn into safemode.
Keep in mind that in this mode only inbuilt system app will wor
Tech Talk
I do it recently but no changes appear
Then i contact the service centre they told its an battery issue and replaced the battery but still the complaint is here
Ehsank
Tech Talk
they replaced battery but problem not resolved, its ok but go again and share these things, tell them that still problem persist.
and request them to resolve your issue, after all that is Samsung service centre
Tech Talk
If any software bug effects this issue
Ehsank
Tech Talk
I don't think bro, this is software bug
do visit again may be this time they will take your phone for 24hrs for their observation
Tech Talk
Ok bro thank you
cs-member13
Expert Level 4
Tech Talk
Dear Samsung Member,
We apologize for the inconvenience caused to you. To resolve battery issue kindly follow the below given step:-
- Battery optimization:- Settings > Select Device Maintenance/Device Care>Optimize>Optimize all options like Battery, Storage and Memory
For more information on battery drainage please click on the link below:-
http://www.samsung.com/in/support/skp/faq/1101689
If the issue still persist, kindly register your concern in Samsung Members app (Samsung Members app > Get help > Feedback > Error report/ask question). Kindly send us the screenshot (which apps are consuming most of the battery).
Note: Please send device log files within 15 minutes of issue occurrence along with the exact issue details.
