12-14-2024 07:55 PM (Last edited 12-14-2024 08:29 PM ) in
Tech Talk- « Previous
- 1
- 2
- Next »
12-14-2024 10:19 PM in
Tech Talk- Mark as New
12-14-2024 10:23 PM in
12-14-2024 09:30 PM in
12-16-2024 06:16 PM in
Tech TalkDear Samsung Member,
We regret to hear about your experience with our product.
To fix battery drain issue please use the link to perform some easy troubleshooting steps: https://www.samsung.com/in/support/mobile-devices/how-can-i-optimise-and-extend-the-battery-life-on-...
You can reset your device by following the steps:
3. If you do not remember then reset (Forgot password) your Google account.
If the issue still occurs, please visit the service centre for a physical inspection of your device. You can locate your nearest service centre with this given link: https://www.samsung.com/in/support/service-center/
- « Previous
- 1
- 2
- Next »
