Battery Drain Issue During Screen-Off Mode
(Topic created on: 12-14-2024 07:55 PM)
mahemJ
Tech Talk
I’ve noticed one more thing: The battery consumption during the day is quite good, with an expected percentage of drain. However, the issue arises when the screen is completely off—it drains significantly, which is quite surprising.
Please note that not any single application was open or downloading or updating anything.
I’ll definitely be highlighting this concern as a request for improvement.
13 Comments
Krishna7662
Tech Talk
Hello
mahemJ
Tech Talk
Hi
RamkeeHabeeb
Tech Talk
Same with my mobile, samsung must fix this issue
Yogie09
Tech Talk
Dude, it's obvious you're using a Beta software so these things are expected & should get fixed by the time the stable version is released...for the moment, you can only just highlight issues that you're facing..that's the purpose of the Beta programme..!!
mahemJ
Tech Talk
Have you read my whole post ?
I am not complaining
I am requesting them to these issues for interception
Dude......!😂
Tech Talk
Add apps to deep sleep to avoid background battery consumption, follow the steps as screenshot
If you like the information than mark as solution from 3 dots1734189403712.jpg1734189403727.jpg1734189403744.jpg1734189403759.jpg
mahemJ
Tech Talk
I have been using the Deep Sleeping Apps feature since 2021, when it was introduced with One UI 4 on Android 12.
I have added all non necessary apps into deep sleeping app list
Still facing this power draining issue
mahemJ
Tech Talk
Tech Talk
