After android 11 update problem.
(Topic created on: 01-24-2021 09:08 PM)
Chailoverdr37
Tech Talk
After android 11 update my otg pandrive or harddrive video folder not show any video player and show in only file manager and to change video or audio  to every time time to go file manager and change. any buddy face this problem.
2 Comments
Ehsank
Tech Talk
perform these below steps; start with C
A. Wipe Cache Partition.
Steps to perform.
1) Turn off the device.
(Connect with type C cable and connect withpc/laptop/type C earphone only for Android 11 )
2) Press and hold the Volume Up key and the spower button.
3) When the Android logo displays, release all keys.
4) Press the Volume down key to navigate and select "Wipe cache partition".
5) Press Power key to select. When the wipe cache partition is complete, Select Reboot System.
6) Press the Power key to restart the device.
B. Reset App Preferences.
Settings >Apps> Tap on Top Right 3Dots and select Reset App preferences.
C. Go to settings >general Management >reset>reset settings.
Chailoverdr37
Tech Talk
Thanks you bro. i have all ready try it but not any chang.
