Second screen display using wired connection
(Topic created on: 04-14-2021 12:42 PM)
royabhi028
Tablets
The second display using the wired connection lags in my case(tab s7).  I want to use the second display using wired connection.  Is there a way to do that?
2 Comments
Tablets
Right now I believe there is no way from the actual built in second screen app as it is a wireless display but you can do it from a third party app called super display. You will have to downlaod super display both on your tablet and pc I had trouble making it work but you might want to give it a shot.
royabhi028
Tablets
thanks a lot
