Battery drain !
(Topic created on: 08-29-2023 09:16 AM)
Anujak
Tablets
I bought a samsung s8 tab 5g about 2 months ago but it battery drain very fast last about only 7-8 hrs .
And major problem is that its last left 10% wouldn't last more than 5 minutes.
Is my tablet battery is worthless or deteriorate???
Please tell me!
4 Comments
cs_member8
Tablets
Dear Samsung Member,
We acknowledge your query. Please visit this mentioned link and follow the steps to resolve the battery drain issue
https://www.samsung.com/in/support/mobile-devices/what-to-do-if-the-battery-of-my-new-phone-seems-to...
In case the issue still occurs. Please visit the service center for a physical inspection of your device. You can locate your nearest service center with this given link:
https://www.samsung.com/in/support/service-center/
CODM6567
Tablets
Common problem among Samsung devices.
It's an advice don't drain battery past 15%.
Use Dark mode(if brightness >40%)
Use Dark wallpaper
Turn off adaptive brightness
Turn off quick share
Switch to light mode in performance profile
Put unused apps to deep Sleep
Turn on location services for while using apps only
AOD as Tap to show
Turn off 5g
You can also try these routine
Anujak
Tablets
If i turn all the things of then what would i do with the tablet😒
CODM6567
Tablets
You can follow some which are appropriate and as per requirement
